TD21 Brake Pipe Query
For all TD 21, TE 21, TF 21 and TC108G cars
durhamsmudger
Postby durhamsmudger » Fri Jan 11, 2019 5:24 pm
Hi
I am just starting the process of replacing all the car's brake lines - what a hodge podge !
Ive found a combination of 3/16" & 1/4" pipe and associated fittings, aluminium and copper.
My question is, should everything be 1/4" pipe 7/16" fittings?
Thanks
Cheers
Alan
Re: TD21 Brake Pipe Query
Postby RichardWallach » Fri Jan 11, 2019 10:27 pm
Alan,
I would give Chris Prince a call. My TA21 has the same "bundy" type pipe throughout the chassis. I have no reason to see why yours should be any different unless altered in the past.
durhamsmudger
Postby durhamsmudger » Sat Jan 12, 2019 1:48 pm
Yes I will, I'm going to his place at the end of the month to pick up some unpostable bits, so I'll take a list of questions as well
Cheers
Cheers
Alan
Postby RichardWallach » Mon Jan 14, 2019 8:27 am
Alan,
I checked the piping on the TA21. The tube nuts are 7/16th UNF which take 1/4inch pipe work. You will find that a 11mm metric brake spanner will be a very good fit for the 7/16th fittings.
durhamsmudger
Postby durhamsmudger » Mon Jan 14, 2019 4:27 pm
Cheers
Cheers
Alan
Return to “TD, TE and TF”
